Parallella Community • View topic - Downloading/Building the SDK and Reporting Issues
Postby simoncook » Tue Feb 19, 2013 10:42 am
Useful SDK Links: - - -
simoncook
Self hosting toolchain?
Postby madtom1999 » Tue Jul 30, 2013 12:08 pm
Just wondering if anyone has built the toolchain so it runs on the card?
madtom1999
Re: Self hosting toolchain?
Postby simoncook » Tue Jul 30, 2013 12:19 pm
simoncook
Postby ysapir » Tue Jul 30, 2013 2:23 pm
ysapir
Re: Downloading/Building the SDK and Reporting Issues
Postby madtom1999 » Tue Jul 30, 2013 3:03 pm
Thanks.
madtom1999
Postby Gravis » Sun Aug 25, 2013 11:29 am
@simoncook
you should update the github links since everything got merged to adapteva. i'm betting there are a few other places (and files) that have this same issue too. grep and LIKE for all! :)
Gravis
Postby AndrewStone » Tue Jul 15, 2014 2:49 pm
AndrewStone
Postby jeremybennett » Tue Jul 15, 2014 4:00 pm
Hi Andrew,
Thanks for spotting this. Would you raise an issue on the SDK github repository, so we can track it getting fixed.
Best wishes,
Jeremy
jeremybennett
Postby Gravis » Tue Dec 09, 2014 11:46 pm
Gravis
Postby louloizides » Thu Apr 02, 2015 2:58 am
Any updates on building the Mac SDK? I can't seem to get arm-none-linux-gnueabi-gcc installed and according to the wiki it's a requirement (correct me if I'm wrong).
Last login: Fri Mar 27 21:55:35 on ttys001
MacBook-Pro:~ louloizides$ sudo port install arm-none-linux-gnueabi-gcc
Warning: port definitions are more than two weeks old, consider updating them by running 'port selfupdate'.
Waiting for lock on /opt/local/var/macports/registry/.registry.lock
Portfile changed since last build; discarding previous state.
---> Fetching archive for arm-none-linux-gnueabi-binutils
---> Attempting to fetch arm-none-linux-gnueabi-binutils-2005q3-2_0.darwin_14.x86_64.tbz2 from http://packages.macports.org/arm-none-l ... i-binutils
---> Attempting to fetch arm-none-linux-gnueabi-binutils-2005q3-2_0.darwin_14.x86_64.tbz2.rmd160 from http://packages.macports.org/arm-none-l ... i-binutils
---> Computing dependencies for arm-none-linux-gnueabi-binutils
---> Deactivating arm-none-linux-gnueabi-binutils @2005q3-2_0
---> Cleaning arm-none-linux-gnueabi-binutils
---> Uninstalling arm-none-linux-gnueabi-binutils @2005q3-2_0
---> Installing arm-none-linux-gnueabi-binutils @2005q3-2_0
---> Activating arm-none-linux-gnueabi-binutils @2005q3-2_0
---> Computing dependencies for arm-none-linux-gnueabi-gcc
---> Dependencies to be installed: arm-none-linux-gnueabi-runtime
---> Extracting arm-none-linux-gnueabi-runtime
---> Configuring arm-none-linux-gnueabi-runtime
---> Building arm-none-linux-gnueabi-runtime
---> Staging arm-none-linux-gnueabi-runtime into destroot
Warning: arm-none-linux-gnueabi-runtime installs files outside the common directory structure.
---> Installing arm-none-linux-gnueabi-runtime @cs2005q3.2_0
---> Activating arm-none-linux-gnueabi-runtime @cs2005q3.2_0
---> Cleaning arm-none-linux-gnueabi-runtime
---> Fetching archive for arm-none-linux-gnueabi-gcc
---> Attempting to fetch arm-none-linux-gnueabi-gcc-2005q3-2_0.darwin_14.x86_64.tbz2 from http://packages.macports.org/arm-none-linux-gnueabi-gcc
---> Attempting to fetch arm-none-linux-gnueabi-gcc-2005q3-2_0.darwin_14.x86_64.tbz2 from http://mse.uk.packages.macports.org/sit ... nueabi-gcc
---> Attempting to fetch arm-none-linux-gnueabi-gcc-2005q3-2_0.darwin_14.x86_64.tbz2 from http://lil.fr.packages.macports.org/arm ... nueabi-gcc
---> Fetching distfiles for arm-none-linux-gnueabi-gcc
---> Attempting to fetch gcc-2005q3-2.tar.bz2 from http://ykf.ca.distfiles.macports.org/Ma ... tfiles/gcc
---> Attempting to fetch gcc-2005q3-2.tar.bz2 from http://svn.macports.org/repository/macp ... les/pguyot
---> Verifying checksums for arm-none-linux-gnueabi-gcc
---> Extracting arm-none-linux-gnueabi-gcc
---> Applying patches to arm-none-linux-gnueabi-gcc
---> Configuring arm-none-linux-gnueabi-gcc
---> Building arm-none-linux-gnueabi-gcc
Error: org.macports.build for port arm-none-linux-gnueabi-gcc returned: command execution failed
louloizides
