Parallella Community • View topic - can you put a Forth compiler into each DSP core?
Moderator: timpart
Re: can you put a Forth compiler into each DSP core?
Postby timpart » Thu Jul 18, 2013 12:49 pm
Postby svartalf » Thu Oct 03, 2013 4:12 pm
svartalf
Postby svartalf » Thu Oct 03, 2013 4:21 pm
svartalf
Postby bithead » Fri May 23, 2014 4:05 pm
bithead
Postby timpart » Sun May 25, 2014 7:04 pm
Postby 9600 » Mon May 26, 2014 1:41 pm
Postby eleitl » Mon May 26, 2014 1:55 pm
eleitl
Postby CIB » Sat Jun 28, 2014 9:13 am
CIB
Postby holder66 » Sat Apr 18, 2015 9:01 pm
I note with interest that the epiphany core has 64 registers. A few years ago, I programmed a neural network based pattern classifier in Power MacForth, a forth dialect that made use of the large number of registers in the PowerPC architecture to provide for passing named parameters (up to 8) to functions, which could be accessed as named local variables within the function, and of course made it child's play to call functions recursively. This not only made forth programming much easier since far fewer stack rearranging was necessary, it was also very fast. And the code was readable!
I hope that someone implements a forth machine on the parallela architecture. My pattern classifier would benefit greatly from running on multiple cores.
holder66
Postby ASterbini » Mon May 01, 2017 3:36 pm
(from a recent Parallella owner)
While I was looking for a mips forth to put on the Epiphany cores
I found gForth (with metacompiler and cross compiler) and mips-forth,
a threaded forth implemented for the Spim simulator.
Has anybody tried to put gForth on Epiphany?
ASterbini
Return to Forth
