Parallella Community • View topic - How do you alias a register?
Postby Gravis » Mon Apr 20, 2015 3:08 am
Gravis
Re: How do you alias a register?
Postby cmcconnell » Mon Apr 20, 2015 1:40 pm
#define will work if you use gcc on a file with a .S extension. (gcc will run the file through the C preprocessor before invoking the assembler.)
Colin.
cmcconnell
Postby Gravis » Mon Apr 20, 2015 2:25 pm
Gravis
Postby cmcconnell » Mon Apr 20, 2015 2:51 pm
You're welcome.
I don't know if there are alternatives to using #define which might have advantages. I just stumbled upon the technique while looking through some example code. (Until I saw the example, I hadn't even realised you could use gcc, rather than as, and thus make use of the preprocessor.)
Colin.
cmcconnell
Return to Assembly
