Parallella Community • View topic - generating epiphany code from templates, possible?
Postby dobkeratops » Sun Aug 09, 2015 8:08 am
Last edited by dobkeratops on Tue Aug 18, 2015 12:51 am, edited 15 times in total.
dobkeratops
Re: generating epiphany code from templates, possible?
Postby theover » Sun Aug 09, 2015 11:36 am
The technical matters and your grasp of them might be a bit in the way here. A C++ compiler would be a thing to have first. The whole intercommunication with the Epiphany cores needs to be created and put in the compiler, and I think there's only C, so the class code would have to be ported, too.
Nothing against making a template, you could do it yourself, but whether you are willing to write a compiler for it ?
T.
Postby dobkeratops » Sun Aug 09, 2015 11:56 am
dobkeratops
Postby dobkeratops » Sun Aug 09, 2015 12:07 pm
dobkeratops
Postby dobkeratops » Sun Aug 09, 2015 2:40 pm
dobkeratops
Postby piotr5 » Mon Aug 10, 2015 10:42 am
I'm not really convinced of your approach. if epiphany were a fpu, then compiler could treat it as extended assembler-syntax. but epiphany can actually execute sequential code and has no hardware-support to put such code into sequence. better imho is software-emulation for task-switching on epiphany. i.e. on arm you program in a way as if epiphany didn't exist, load and run programs on epiphany as usual. that's good because it reflects the slow connection between the two processors. then on epiphany do as you suggest, assign some free core at runtime or compiletime to execute the task you want, copy over code to the core's local memory or let it run instruction by instruction from the current core. only problem is code-relocation when multiple tasks are running. basically that's 2 approaches: runtime or compiletime. when decisions are at runtime, this allows to run 2 programs on your epiphany. if compiletime you must own the whole epiphany chip...
piotr5
Postby dobkeratops » Mon Aug 10, 2015 12:25 pm
dobkeratops
Postby piotr5 » Tue Aug 11, 2015 12:55 pm
piotr5
Postby dobkeratops » Tue Aug 11, 2015 10:15 pm
dobkeratops
Postby dobkeratops » Wed Aug 12, 2015 3:05 am
dobkeratops
