Parallella Community • View topic - PL fabric clock
PL fabric clock
PL fabric clock
Postby a_k » Wed Feb 17, 2016 9:52 am
Hi
I'm having some trouble getting the PL clocks to work (e.g. FCLK_CLK1). All I want is to route it to an I/O pin to use it with external hardware. I got a similar design running on a zedboard just fine, but I read that it is different on a Parallella. Apparently, the PL fabric clock configuration (FCLK_CLK0..3) is made in the PS. I saw people saying this gets configured in the FSBL, but on the Parallella, I don't have access to the FSBL because the operating system is loaded directly by the on-board u-boot bootloader and not the custom FSBL on the SD card. If this all is correct, I would have to change the clocks from the PS, but how do I do that? I don't think there can be much wrong with my design, as I am basically just routing a signal to an I/O and the other signals I have routed to an I/O are working fine. Or is there an additional step I might have missed?
a_k
Re: PL fabric clock
Postby peteasa » Fri Feb 19, 2016 4:24 pm
If you just change the clock speed in Vivado and rebuild the fpga then the bit stream created is not changed. When you use Vivado and create a new board support package the clock speeds selected for the PL clocks are saved in the board support package software. So the board support package is the only piece that is changed when you only configure changes to FCLK PL clocks in Vivado. The shipping first stage boot loader uses the board support package that was created some time ago and this then uses this old board support package to configure the clocks and fpga at startup. It is not possible to change the clock speed on the fly after boot because this change in clock would cause problems with various bits of hardware.
To change the clock speed you have to build a new board support package and create a new fsbl and flash this to the parallella via jtag.
I2C is used to configure the voltage regulators. In the fsbl the I2C interface is used to set the GPIO pin voltages. If you change the fpga then you must ensure that the I2C interface used is not changed so that the fsbl can still configure the voltages correctly.
You might find this of use: http://parallellagram.org/parallella-fp ... sion-cards
You might also find this of use: viewtopic.php?f=51&t=3297
Peter.
peteasa
Re: PL fabric clock
Postby kirill » Sun Feb 21, 2016 1:33 am
kirill
Re: PL fabric clock
Postby kirill » Sun Feb 21, 2016 5:50 am
kirill
Re: PL fabric clock
Postby a_k » Wed Feb 24, 2016 8:40 am
a_k
Re: PL fabric clock
Postby kirill » Wed Feb 24, 2016 10:06 am
But you do have them, it's just xdevcfg driver requires 3 step procedure:
1. echo fclk0 into /sys/{whatever_path_on_your_system}/fclk_export (Only then /sys/class/fclk/fclk0/* will appear)
2. Then enable it by echo 1 into /sys/class/fclk/fclk0/enable
3. Then change frequency by echo {needed_frequency_in_Hz} into /sys/class/fclk/fclk0/set_rate
Repeat for other clocks as needed by changing fclk0 to fclk{1,2,3}
kirill
Re: PL fabric clock
Postby a_k » Wed Feb 24, 2016 10:41 am
Ah, ok, now I see. I thought you first have to change the parameters and then export them to apply the changes. Thank you! It works like a charm now!
a_k
Re: PL fabric clock
Postby kirill » Wed Mar 16, 2016 10:47 am
For future references here is a script for changing fabric clocks from Linux
https://gist.github.com/Kirill888/24385a36697959924d78
Or for direct download:
https://gist.github.com/Kirill888/24385 ... a/fclk_set
kirill
Re: PL fabric clock
Postby MelHance » Sat Aug 05, 2017 4:43 pm
MelHance
