Parallella Community • View topic - [Porcupine] Pin Mapping, Voltages and Other Questions
Postby miguel_rodrigues » Wed Jun 08, 2016 3:42 pm
Hi there,
I have been using Parallella Embedded (Zynq 7020) for a couple of months and have recently acquired a Porcupine board but I have not used it yet. My main interest is FPGA development and finally, it's time to use the available GPIO. However, I have some questions and I wonder if you might help me:
- The Parallella Manual (http://www.parallella.org/docs/parallella_manual.pdf) says that the "PEC_FPGA includes 48 bidirectional signals that can be configured within the Zynq device to support a number of different signal standards, including LVCMOS and LVDS". However in the Porcupine board, I only see 24 pins connected to the PEC_FPGA. What is the relationship between these 24 pins and the aforementioned 48 IOs?
- Is it possible to use LVCMOS33 or only LVCMOS25? What about LVTTL?
- Table 7 in Parallella Manual (regarding pin assignments) is incomplete. What is the mapping between the Zynq pins and GPIOs?
- Porcupine also comes with a PMOD. To which Zynq pins are the PMOD IOs connected? Are they connected to the PL part of the Zynq?
Many thanks in advance :D
PS: The reason I want to use the Porcupine is to be able to debug my FPGA designs and to interface Parallella with other hardware such as (other) FPGAS and image sensors.
miguel_rodrigues
Re: [Porcupine] Pin Mapping, Voltages and Other Questions
Postby miguel_rodrigues » Fri Jun 17, 2016 9:59 am
miguel_rodrigues
Postby miguel_rodrigues » Fri Jun 17, 2016 12:45 pm
Ok, new update :)
I have been experimenting with this and I am now able to use the 48 GPIOs of Porcupine/Parallella. I am using them with LVCMOS25 but I would like to know if I may use them with LVCMOS33 without frying the board. Maybe this is a dumb question, I am almost certain that I can use such standard but I can not afford another Parallella if I fry this one. So:
Is it safe to use LVCMOS33 for using the GPIO?
Thanks in advance :)
miguel_rodrigues
Postby aolofsson » Fri Jun 17, 2016 8:32 pm
I wouldn't recommend that, but the GPIO voltage can be changed to 3.3V through the I2C. I think patc used 3.3V for his audio project?
Here is an example how to modify the epiphany voltage as a starting point.
viewtopic.php?f=49&t=2285
Sorry, can't help out more than that right now...
Users browsing this forum: No registered users and 28 guests
