New Parabuntu 2016.11 Release
Postby aolofsson » Mon Dec 12, 2016 2:01 am
https://www.parallella.org/2016/12/12/p ... 11-release
Highlights:
HDMI improvements (Thanks to Peter Saunderson and Ola Jeppsson)
GDB Epiphany multicore support (Thanks to Pedro Alvez)
EPYTHON parallel programming framework (Thanks to Nick Brown)
OpenMP 4.0 Device Support (Thanks to University of Ioannina)
OpenCL (Thanks to Brown Deer Technologies)
PAL Epiphany backend (Thanks to Ola Jeppsson)
Fallback support for FPGA only loads (Thanks to Ola Jeppsson)
Epiphany multicore simulator support (Thanks to Ola Jeppsson)
GCC 5.4 Epiphany Upgrade
GDB 7.12 Epiphany Upgrade
Re: New Parabuntu 2016.11 Release
Postby Claggy » Mon Dec 12, 2016 3:04 pm
The Release notes aren't there yet, and the links to the binaries get 404 file not found errors.
Claggy
Claggy
Postby aolofsson » Mon Dec 12, 2016 3:21 pm
Thanks for reporting! Sorry about that, forgot to press publish button on github. Try now.
Postby Claggy » Mon Dec 12, 2016 3:40 pm
Claggy
Claggy
Postby dragon1818 » Fri Dec 23, 2016 8:18 am
I found some bugs on parabuntu-2016.11.1-hdmi-z7010.img.gz:
1) USB port not working correctly, when I debug it using lsusb it prompt some error message and the attached usb devices were not working.
2) HDMI not working correctly, I believe it was the HDMI that did not detect the monitor screen resolution and display it on a correct resolution based on the monitor screen. I have tested it on 2 different monitors which one turn out to be total black screen and another one which only display a portion of the screen itself.
dragon1818
Postby tddial » Mon Dec 26, 2016 8:47 am
One comment and one question about this release:
Comment: the screensaver (xscreensaver 5.30 as I remember) did not, for me, unlock when provided with the correct password. This isn't a problem in the environment in which the Parallella lives, but wss an annoyance. I purged the package.
Question: the user parallella belongs to three groups - 1001 (admin), 1002 (bluetooth), and 1003 (pulse-access) that are in the customary Debian/Ubuntu range for private user groups. There are no such users defined to the OS, and no files with those values as gid. I want to create additional users and for network and system administration reasons want to assign those values to new user IDs and corresponding private group IDs. Is there a reason that requires those groups to have those particular values or can I change them to other values in the system group range without causing myself future difficulties?
tddial
Postby mrbarre1 » Mon Jan 02, 2017 10:36 pm
I am using ParaUbuntu 2016.11 on a microserver and so far no problems. I have not played around with the Parallella in almost a year. I must say the new release is a big improvement in my opinion especially for someone like myself who is a novice in this area of computing. I think with the changes that have been made I will be able to move forward learning about parallel programming. Thanks for the effort it took to make this happen.
mrbarre1
Postby mchampigny » Tue Jan 03, 2017 12:30 pm
I can verify two of the problems described in your post:
X-screensaver won't accept password to unlock. I actually ended up shutting down to get out of it from VNC. I simply disabled the screensaver since I don't need it anyway using a remote display.
I can't get the USB port to work at all. I tried multiple adapters and various USB gadgets. I get the same error message as you with lsusb.
However, HDMI is working fine for me. Because I can't use the USB, I use VNC to connect to the display (or just SSH in most of the time).
mchampigny
Postby mchampigny » Sun Jan 08, 2017 7:17 pm
As a follow-up, I was able to get the USB port working using a powered USB hub. I tried both a non-powered hub and a direct micro-USB cable and those would not work.
So if you are having problems with the USB, try a powered USB hub.
mchampigny
Postby Claggy » Sat Feb 11, 2017 5:23 pm
Got the 2016.11.1 release running on my Kickstarter Parallella, Built Boinc, and have the Seti and Seti Beta apps running on it.
HDMI Works at 1920*1200, But there is a lot of screen corruption happening, has there been fpga voltage changes since the earlier images?
Claggy
Claggy
Return to Linux/U-Boot
