Technical Details Epiphany-V
Postby stefanluik » Tue Mar 14, 2017 9:25 am
could you tell some details about the chip ?
- Package size
- 16-bit external chip-addressing ?
- connection speed
Stefan
stefanluik
Re: Technical Details Epiphany-V
Postby olajep » Sat Apr 01, 2017 6:08 am
Some of the info is available in the Epiphany-V Technical Report:
https://www.parallella.org/2016/10/05/e ... processor/
https://www.parallella.org/wp-content/u ... re_soc.pdf
stefanluik wrote:- 16-bit external chip-addressing ?
I don't understand this question.
stefanluik wrote:- connection speed
Total chip IO Bandwidth: 192 Bytes / IO clock cycle
// Ola
Reason: quote formatting
Postby dobkeratops » Sat Apr 01, 2017 9:57 am
what would a ballpark "IO Clock Cycle" be, I understand you may want to clock it at different rates
is the potential bandwidth the same for GPIO and inter-chip links
dobkeratops
Postby olajep » Sat Apr 01, 2017 11:31 am
dobkeratops wrote:what would a ballpark "IO Clock Cycle" be, I understand you may want to clock it at different rates
Probably enough ;) (sorry I'm not going to speculate).
dobkeratops wrote:is the potential bandwidth the same for GPIO and inter-chip links
In real world applications perhaps maybe guestimate an order of magnitude slower.
There's also a raw data streaming mode in the MIO block, so for higher frequencies you'd probably use that.
Postby stefanluik » Mon Apr 03, 2017 9:29 am
thanks for replies,
I want just some secured infos:
- 1 billion processors are 1.000.000.000 processors. right ?
- what space is needed for the total chip ? what form factor (bga ...) is the total chip ?
- what will be the momentan thinking speed in GHz of the connection ports to neighbour chip ?
This infos are just for planning / designing a system like a supercomputer.
Thanks for
stefanluik
Postby sebraa » Mon Apr 03, 2017 10:58 am
I do not think you will get any secured infos. But I can speculate (since I am not with Adapteva and have never been). :-D
A billion according to the US is 1.000.000.000.
Epiphany G3 and G4 chips are only available in BGA, so I would assume the same for G5. If they will be available to the public at all.
Given the 1024 GPIO signals specified, you can infer a reasonable package size.
The interconnect clock rate will be limited by the same physics that any other system has to deal with.
Do not expect miracles, only good engineering.
Users browsing this forum: Bing [Bot], Google [Bot] and 20 guests
