ePython error on first run for multicore code
Postby GlasierXplor » Tue May 09, 2017 3:51 pm
I tried to run a simple ePython code and I got the following error:
epython-host: e_reset_system(): EPIPHANY_DEV file open failure.
Error on system reset
epython-host: e_open(): EPIPHANY_DEV file open failure.
Error opening Epiphany
epython-host: e_alloc(): EPIPHANY_DEV file open failure.
Error allocating memory
/usr/bin/epython: line 28:  2079 Segmentation fault      $FILE "$@"
How can I solve this?
GlasierXplor
Re: ePython error on first run for multicore code
Postby polas » Tue May 09, 2017 11:41 pm
Hi - I am sorry you are having difficulties with this. Is this the preinstalled ePython on the latest OS image distro or a version you have installed from the Git repo yourself? Are you using the latest OS image, or is this an older image? What command are you using to launch ePython?
Nick
polas
Postby GlasierXplor » Wed May 10, 2017 7:46 am
Hi!
I tried running stock ePython from Parabuntu 15.04 (latest image), by using `epython code.py`. I got and error saying that `parallel.py cannot be found`.
So I thought that there might be some problem with the ePython, so I downloaded it from Git. After installing, and running again using `epython code.py`, I got the error I mentioned in my first post.
Thank you for helping!
GlasierXplor
Postby sebraa » Wed May 10, 2017 9:28 am
Can you try running it like "sudo epython code.py"?
Postby GlasierXplor » Wed May 10, 2017 9:32 am
sebraa wrote:Can you try running it like "sudo epython code.py"?
by default
I am logged into the root account by default.
GlasierXplor
Postby polas » Wed May 10, 2017 3:13 pm
GlasierXplor wrote:I am logged into the root account by default.
Ah I wonder if this might be the issue with it not finding parallel.py, I suspect the module paths are just set up for the parallella user rather than root. Instead of logging in as root can you try running (the preinstalled version ideally) of ePython as the parallella user on a test code to see if that works? It shouldn't need to be run with root privileges (either as root or sudo.)
The errors you are seeing seem to suggest some issue with launching/communicating with the Epiphany, again I wonder if this is because you are logged in as root rather than the parallella user.
Nick
polas
Postby olajep » Fri May 12, 2017 1:41 pm
Append this to /root/.bashrc
#EPYTHON
export EPYTHONPATH=/usr/include/epython/modules:$EPYTHONPATH
But I recommend logging in as the parallella user. No need to be root
// Ola
Postby GlasierXplor » Sat May 13, 2017 4:01 pm
olajep wrote:But I recommend logging in as the parallella user. No need to be root
Every time I boot up Parallella it automatically logs me into the root account.
When I issue `logout` it does log out, but then it automatically logs me in as root again.
GlasierXplor
Postby GlasierXplor » Sat May 13, 2017 4:07 pm
polas wrote:Instead of logging in as root can you try running (the preinstalled version ideally) of ePython as the parallella user on a test code to see if that works? It shouldn't need to be run with root privileges (either as root or sudo.)
Output if I run without root privileges (same as before)
/usr/bin/epython: line 28:  2107 Segmentation fault      $FILE "$@"
Output when run with root privileges
/usr/bin/epython-host: error while loading shared libraries: libe-hal.so.0: cannot open shared object file: No such file or directory
Oh and when I request for root privileges (sudo), it doesn't prompt me for a password,
GlasierXplor
Postby olajep » Sat May 13, 2017 7:47 pm
Which board model do you have?
Are you sure that you have downloaded the right image?
Instructions here:
https://www.parallella.org/create-sdcard/
Please post the output of
$ lsmod
$ sudo rmmod epiphany
$ sudo modprobe epiphany
$ dmesg
on a fresh boot
// Ola
