Parallella Community • View topic - Memcpy slow compared to manual copy of data
Postby pascallj » Thu Jun 15, 2017 12:40 pm
pascallj
Re: Memcpy slow compared to manual copy of data
Postby pascallj » Thu Jun 15, 2017 2:03 pm
Think I got at least one problem figured out. If copy memcpy from into my own code, it results in roughly the same benchmark values as when I adapt my own code to copy 8 instead of 64 bits. So I guess the low memcpy performance comes from the standard C library being in the external dram instead of SRAM.
However I am still wondering why O3 will, instead if optimizing my code for speed, makes my code so much slower.
pascallj
Postby sebraa » Thu Jun 15, 2017 4:06 pm
Do not execute any code from external memory if you want reasonable performance. Use internal.ldf as linker script.
Postby pascallj » Thu Jun 15, 2017 4:23 pm
pascallj
Postby jar » Thu Jun 15, 2017 5:08 pm
You can use my shmemx_memcy routine if you need best performance. Nothing else beats it while also handling address misalignment.
https://github.com/USArmyResearchLab/op ... x_memcpy.c
Postby pascallj » Thu Jun 15, 2017 5:25 pm
Thanks! I am using the Parallella board for my bachelor thesis so maybe it is nice to compare the results I finally get with your implementation.
pascallj
Postby GreggChandler » Fri Jun 16, 2017 7:44 am
GreggChandler
Postby GreggChandler » Fri Jun 16, 2017 8:46 am
GreggChandler
Postby sebraa » Fri Jun 16, 2017 12:16 pm
Postby DonQuichotte » Fri Jun 16, 2017 3:09 pm
Totally agree with sebraa.
Performance is my only goal.
Use internal.ldf or nothing.
Avoid using the libraries as much as possible.
gcc bit handling emulation for example is really poor, I had to replace them with my own (popcount, clz).
DonQuichotte
Users browsing this forum: No registered users and 46 guests
