Parallella Community • View topic - Why port array languages such as Apl to Parallella ?
Moderator: Dr.BeauWebber
Postby Dr.BeauWebber » Tue May 28, 2013 8:20 pm
Dr.BeauWebber
Re: Why port array languages such as Apl to Parallella ?
Postby aolofsson » Wed May 29, 2013 1:31 am
Dr. Webber,
Thank you so much for porting APL to Parallella! This totally makes my day!
If I understand correctly, you are suggesting something like pipes to communicate between APL programs running on different cores. Any thoughts on the possibility of actually extracting data parallelism and computation from the APL program. Does APL have properties that makes it a better starting point for "auto parallelizing compilers" compared to standard procedural languages like C? I know there have been some publications to this effect, but not sure how practical it is.
Postby Dr.BeauWebber » Wed May 29, 2013 9:47 am
Dr.BeauWebber
Postby Dr.BeauWebber » Wed May 29, 2013 11:58 am
Dr.BeauWebber
Postby Dr.BeauWebber » Wed May 29, 2013 5:08 pm
I have started a new topic : Inter-process communication on the Parallella to continue this communication discussion.
Dr.BeauWebber
Postby shr » Sun Aug 04, 2013 10:41 pm
Array programming lanugages should be a good fit for the Parallella, though efficiently mapping APL and friends to its architecture will take some work.
shr
Return to APL
Users browsing this forum: No registered users and 47 guests
