Example: Reducing run time by moving code to internal memory
Moderator: Dr.BeauWebber
Re: Example: Reducing run time by moving code to internal me
Postby Dr.BeauWebber » Thu Jun 20, 2013 8:51 am
Yes I tend to skim-read TFM initially and then should go back to it later and read it more carefully ....
The speed on next test is really puzzling me, I will want you to check the steps for me :
Example: In-line maths calculation, in internal memory.
Dr.BeauWebber
Postby 9600 » Thu Jun 20, 2013 11:45 am
Dr.BeauWebber wrote:Yes I tend to skim-read TFM initially and then should go back to it later and read it more carefully ....
I think you are far from alone in this respect :D I have to admit that I do it _all_ the time.
Return to APL
