Parallella Community • View topic - Object Detection
Object Detection
Object Detection
Postby notzed » Fri Aug 09, 2013 11:42 am
Re: Object Detection
Postby Gravis » Fri Aug 09, 2013 12:05 pm
i think a more effective approach would be to port to use Epiphany. then you have all the resources of OpenCV which which includes object detection... or you can just rip the part you want for your project and be done with it.
Gravis
Postby notzed » Sun Aug 11, 2013 1:37 am
Postby Gravis » Sun Aug 11, 2013 2:35 am
Gravis
Postby 9600 » Mon Aug 12, 2013 6:53 am
Postby notzed » Wed Aug 14, 2013 1:28 am
Last night I blogged about the story so far.
If all things go well, the next time i have a few hours to hack i should get something going on the epiphany.
Postby aolofsson » Wed Aug 14, 2013 2:18 pm
This is really incredible! Can't wait to see it running on the Epiphany. Hopefully developing software on the device won't be too painful. :D
Note that there has been some success getting the USB working on the gen0. @tnt can probably comment.
You will need to ground the ID pin and make sure you have a device tree that supports USB.
Postby notzed » Sun Aug 18, 2013 12:05 pm
I managed to finally get the object detector code "working" today on a single EPU (epiphany processing unit/core). Well by working, I mean it runs to completion without crashing or hanging. I'm not getting the same results as my laptop yet so i need to do some debugging and also make an ARM version for comparison.
Postby Gravis » Sun Aug 18, 2013 1:10 pm
Gravis
Postby notzed » Mon Aug 19, 2013 5:36 am
