- IMG_20131225_093227.jpg (68.34 KiB) Viewed 71394 times
mine arrived at xmas eve.
Unfortunately I didn't prepare power, sd, mini hdmi etc Fortunately some of the missing accessories are commonly available.
I took my dlink router's adapter 5V/2.5A, zedboard's sd card, copy the boot part (those files in boot partition), connect the network cable, flip the power button.
one green steady light, good sign. then I look up the ip address from the router log, good, got the ip assigned.
so I am able to ssh to the board. that is the working part.
After I did a power cycle, the network never came back even though the leds are blinking green and yellow is on too. I try to connect the host usb, also not working as indicated in the quick start 2 page.
to be continued.
