Parallella Community • View topic - unresponsive board
unresponsive board
Re: unresponsive board
Postby Janos » Thu Mar 13, 2014 6:54 am
Janos
Postby egentalen » Fri Mar 14, 2014 1:11 am
ok, set up with just power supply and serial port. turn power on, and still get nothing at all across ttl. :-(
egentalen
Postby 9600 » Fri Mar 14, 2014 7:41 am
I know you've tried two power supplies, but is one of those the one supplied with the board? And have you fixed the supplied heatsink to the Zynq chip?
Postby egentalen » Fri Mar 14, 2014 1:02 pm
There was no power supply supplied with the board. That might have made this easier.
I put the heat sink on the Zynq chip when I first set up.
egentalen
Postby aolofsson » Fri Mar 14, 2014 1:35 pm
Sory to hear about your issues with the board!
-with the serial cable plugged in and terminal set up, press the reset button (the u-boot boot is VERY fast and short)
-can you provide the name/model of the serial cable you are using
-note that we cannot guarantee (was not characterized) what will happen to the board if you incorrectly connect the TX/RX of the serial port
Can you send an rma request to support@adapteva.com. This doesn't sound very encouraging.
Postby 9600 » Fri Mar 14, 2014 1:39 pm
Apologies, yes, should have "one supplied with the board" — i.e. from the Accessory Bundle.
I suppose it's still possible it is power supply related, and other than which not sure what else to suggest trying.
