Parallella Community • View topic - 5v Fan for board
5v Fan for board
5v Fan for board
Postby hsauro » Sun Mar 16, 2014 6:01 pm
Given the number of people who have recently reported problems with overheating on their boards, has anyone got advice for powering a 5 volt fan from the parallela board? I've found these examples online but want advice on where I can tap 5 volts on the board? I could power the fan separately but a single board solution would be nice as I could strap the fan to the top of the case into a single unit. I think it would be worthwhile the company redesigning the cases they sell to allow a fan to be more easily added.
https://www.etsy.com/listing/116745266/ ... spberry-pi
http://www.ebay.com/bhp/cooler-5v
https://www.youtube.com/watch?v=glFCJ-xEesY
hsauro
Re: 5v Fan for board
Postby 9600 » Sun Mar 16, 2014 7:03 pm
A 5v fan can be powered via the mounting pads if the jumper J15 is fitted. For an example see .
Postby hsauro » Sun Mar 16, 2014 7:15 pm
Thanks for the quick response, just what I needed. Didn't realize there was already a suitable case design.
H
hsauro
Postby gceline » Wed Mar 19, 2014 10:58 pm
Another option if you have the Parallella case - I used this at the Embedded World show where we powered 8 monitors for 4 days at the show.
I used a 5VDC - 25mm x25mm x 6mm fan (easily found as it is used in one of the Apple laptops) and it fits perfectly between the side of the case and the pcb.
I superglued the fan into place and used 5VDC points on on the pcb to power the fan. Pictures at these links.
Graham
Adapteva
gceline
Postby nmalinoski » Sun Apr 20, 2014 11:16 pm
nmalinoski
Postby akidner » Thu May 15, 2014 8:45 pm
I am attaching a picture of my cooling solution. It’s a standard 12v PC case exhaust fan. It was a very low price but quite fiddly to fit. I run it a 5 volts so it is quieter and slower than in normal use.
PC case exhaust fan mounted on the side of the Parallella case
akidner
