Parallella Community • View topic - OpenMP Support
OpenMP Support
OpenMP Support
Postby Takouh » Mon Jan 28, 2013 4:44 pm
I am wondering if there will be an OpenMP SDK for Parallella boards. Is there any information regarding this matter?
Takouh
Re: OpenMP Support
Postby olivererxleben » Mon Jan 28, 2013 5:13 pm
Good question, I thought OpenMP is supported by gcc since 4.2 and I think it is implemented by the ephiphany gcc?!
olivererxleben
Re: OpenMP Support
Postby elecnix » Fri Feb 08, 2013 4:12 am
FastFlow (LGPLv3) claims 35% performance over OpenMP:
http://calvados.di.unipi.it/dokuwiki/do ... pace:about
elecnix
Re: OpenMP Support
Postby tjt7a » Fri Apr 19, 2013 9:24 pm
Is there support for OpenMP?
Tom
tjt7a
Re: OpenMP Support
Postby aolofsson » Fri Apr 19, 2013 11:16 pm
Not yet, but support for OpenMP is in the plans.
Re: OpenMP Support
Postby kblomqvist » Thu Aug 29, 2013 2:13 pm
Forgive my ignorance but wasn't OpenMP support one of the deliverables for Kickstarter backers? "The book "An Introduction to Parallel Programming" to be written by the Adapteva team.(your choice) The book will be provided in PDF form and will include source code examples of parallel programs that use OpenCL, OpenMP, Erlang, and MPI."
Kim
kblomqvist
Re: OpenMP Support
Postby greton100 » Fri Jan 03, 2014 1:47 pm
greton100
Re: OpenMP Support
Postby aolofsson » Fri Jan 03, 2014 8:32 pm
I agree that OpenCL can be quite verbose. Have you looked at some of the OpenCL wrappers out there? We will eventually have openMP ready for release along with other easy to use frameworks.
Let me know if the following example helps at all? I don't think parallel programming is very difficult with the Epiphany at least for simple examples and well suited problems. Perhaps being a hardware person I just have a very high pain threshold. :D
https://github.com/adapteva/epiphany-ex ... parallella
Re: OpenMP Support
Postby greton100 » Tue Jan 07, 2014 7:32 am
greton100
Re: OpenMP Support
Postby dar » Sat Jan 11, 2014 5:18 am
Following up on the discussion of OpenCL wrappers. I would avoid OpenCL wrappers. If the OpenCL API cannot stand on its own, wrappers are not a long term solution. A significant issue is that Epiphany is not a GPU and OpenCL was designed around a GPU. So OpenCL GPU code will take you astray. We have learned this from experience.
Consider STDCL. Its not a wrapper but it leverages OpenCL for portability, at the moment at least, the way other APIs do, like OpenACC (though its very different from OpenACC). STDCL supports Parallella now with the COPRTHR SDK v1.6 released yesterday. The SDK also provides a more direct API that may be of interest in the context of getting OpenMP to work on Parallella for any project aimed in that direction. Many OpenMP implementations use pthreads for a thread pool. The COPRTHR direct API includes a logical extension of pthreads to co-processors. Parallella is a target for support. That may provide a useful connection in the future.
So there are really two interwoven issues here. If you want a quick example of parallel code for Parallella, STDCL is very simple and there are a lot of tools in place, like clcc that supports a standard compilation model - these things are available now, not future projects.
If you are looking for a programming quick start with examples for Parallella, we are hoping to post something within days. No tedious verbose OpenCL headaches. Just simple clean code.
dar
Return to OpenMP
Users browsing this forum: No registered users and 36 guests
