Parallella Community • View topic - Blinking green LED?
Blinking green LED?
Re: Blinking green LED?
Postby bszente » Sat May 24, 2014 9:58 pm
bszente
Postby vdasfbtg » Mon Jun 02, 2014 8:21 am
I am also getting a blinking green LED with both power supply I received. I'll try to replace the capacitors.
Regards
-Valentín
vdasfbtg
Postby Bikeman » Mon Jun 02, 2014 3:10 pm
Hi!
Just a question but is it actually demonstrated that the capacitors themselves are the root course of the failures? Sure they are bulged in the defective units, but that doesn't exclude the possibility that there's something else wrong with those PSUs which causes perfectly normal capacitors to fail after some time....I really don't know whether I would feel comfortable running those PSUs even with replaced capacitors.
HB
Bikeman
Postby bszente » Mon Jun 02, 2014 3:54 pm
bszente
Postby ARHILL999 » Tue Jun 03, 2014 2:13 am
After using the device headless I decided to try a blue tooth adapter on the USB port. When I tried to power it up I now get the dreaded blinking green led. As noted the power supply led also blinks. I have tried several other 3A power supplies and they all behave the same way. It puzzles me why there is no mention of what the blinking means. Someone noted the power is being reset. What is resetting it and under what conditions does this happen. I am comfortable in stating that my power sources are not the problem. I am going to clear the file systems logs and see if anything gets written. If I let it run, the FPGA gets hot but nothing seems to be running either through the Video or Internet.
ARHILL999
Postby bszente » Tue Jun 03, 2014 7:55 am
bszente
Postby FHuettig » Tue Jun 03, 2014 5:13 pm
Postby bszente » Wed Jun 04, 2014 6:50 am
bszente
Postby mercimek » Tue Jun 24, 2014 8:31 pm
@bszente: Hi, that’s true that the sometimes manufactures use the low quality capacitor batch and we can find it with oscilloscope but I am wondering is there any other way to test the capacitor especially with the multimeter?
mercimek
Postby svidgen » Sun Jul 20, 2014 12:57 am
I've emailed support@adapteva.com several times regarding the PSU. (Someone mentioned sending replacements.) But, I haven't gotten any indication that my email was received.
What's going on?
svidgen
