Parallella Community • View topic - Parallella Ubuntu 14.04 release
Postby aolofsson » Thu Jun 12, 2014 12:01 pm
Re: Parallella Ubuntu 14.04 release
Postby hochopeper » Thu Jun 12, 2014 11:12 pm
hochopeper
Postby aolofsson » Thu Jun 12, 2014 11:54 pm
Thanks for reminder. To enable serial port you need to edit and compile the device tree. Very simple and fast operation.(2 minutes) I will add instructions. Long term goal is to get serial port working by default.
Postby hochopeper » Fri Jun 13, 2014 5:12 am
Thanks that seems like it should be easy enough!
I'll have a look into the device tree edits necessary this weekend, I need to do first power up/test of my Parallella this weekend (received it last Friday and haven't had time yet) so I'll have a play with UART stuff after I've got that all going and report back. The readme here - has instruction for compiling the new device tree so plenty of info to get me started.
Chris
hochopeper
Postby shodruk » Fri Jun 13, 2014 12:58 pm
I tried latest ubuntu-14.04 using these files, I experienced some issues.
1f4abc33a27770570c235e3e3ccd0af2 ubuntu-14.04-140603.img.gz
8eab4b6228e32a0432279f76de51300f kernel-hdmi-140603.tgz
d920ca30ce6c1a9b1da841fa18e5dda3 parallella_e16_hdmi_gpiose_7020.bit.bin
1. no network
This is solved by "sudo rm /etc/udev/rules.d/70-persistent-net.rules"
2. no HDMI sound, SMPlayer stuck
not yet solved
3. no usb audio driver
I found that the USB audio driver disabled by kernel config.
Why did you disable it?
4. nano editor is not installed
Nano is a default text editor of Debian/Ubuntu distribution.
5. There are many ~files in the system.
The criminal is Emacs :lol:
Postby aolofsson » Fri Jun 13, 2014 1:10 pm
shodruky,
Thanks for the feedback!!
1.) Sorry, link on the create-sdcard page was outdated, please try again. The right file to download (now linked up):
http://downloads.parallella.org/ubuntu/ ... 611.img.gz
2.) The persistent rule issue should be resolved in the new one.
3). In terms of USB sound, I'll look and see, we might have grabbed an older kernel...stay tuned.
4.) Yes, I also saw the smplayer getting stuck in 14.04 at times. Seemed to be hit and miss? Did you try selecting different sound destinations?
Postby timbat » Sat Jun 14, 2014 5:27 am
I have tried this out tonight. Downloaded all new bitfiles and Ubuntu release and dd'ed to a new partition
I deleted /etc/udev/rules.d/70-persistent etc file with no effect.
My board is hanging at the following state of the boot.
logger: created 256K log 'log_system'
TCP: cubic registered
NET: Registered protocol family 17
Registering SWP/SWPB emulation handler
ALSA device list:
No soundcards found.
EXT4-fs (mmcblk0p2): recovery complete
Freeing unused kernel memory: 188K (c0878000 - c08a7000)
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
init: plymouth-upstart-bridge main process (884) terminated with status 1
�F�W�W�XPocess ended, respawning
init: plymouth-upstart-bridge main process (893) terminated with status 1
0ility groupdded 8 pages/cpu @c160600init: plymouth-upstart-bridge main process (896) terminated with status 1
Q�"F��G��}�Lvͤ٦�$�
timbat
Postby 9600 » Sat Jun 14, 2014 2:49 pm
@timbat, which FPGA bitstream and kernel are you using?
Postby timbat » Sat Jun 14, 2014 5:01 pm
timbat
Postby 9600 » Sun Jun 15, 2014 10:02 am
Hi Tim,
Can you try using the HDMI kernel and FPGA bitstream.
Return to Linux/U-Boot
