Parallella Community • View topic - USB port not working :(
Postby sumitmah » Thu Jul 03, 2014 2:49 pm
I am facing issues with connection usb keyboard or mouse. I am able to create SD card and able to boot up the board.
I've installed Ubuntu 14.04 and kernel with HDMI and GPIO flavers with HDMI on SD card.
1) I can see login screen, but usb mouse and keyboards are not working :(. usb mouse led is also not turning on.
2) When I connect with LAN cable board is not able to boot. If I connect, when already booted then board just keep restarting itself. :(
sumitmah
Re: USB port not working :(
Postby 9600 » Thu Jul 03, 2014 4:04 pm
I'm wondering if the power supply you are using is not holding up once Ethernet or a peripheral is connected. Which power supply are you using? And is the power LED on the board staying constantly lit when you plug things in?
Postby greytery » Thu Jul 03, 2014 4:40 pm
Also are you using a powered USB hub for the mouse/keyboard?
If not, I found I got a lot further in the boot process with just the keyboard connected to the USB port.
Not much use if you want to run Ubuntu (- I know -) but that may help diagnose that your power supply is close to the edge).
Cheers
Postby sumitmah » Thu Jul 03, 2014 5:26 pm
sumitmah
Postby sumitmah » Thu Jul 03, 2014 5:28 pm
sumitmah
Postby 9600 » Thu Jul 03, 2014 5:35 pm
Postby shodruk » Fri Jul 04, 2014 4:40 am
sumitmah,
Don't use the USB port next to the Ethernet port.
Postby sumitmah » Fri Jul 04, 2014 5:23 am
sumitmah
Users browsing this forum: No registered users and 30 guests
