Parallella Community • View topic - Parallella as a Standalone or Embedded Device?
Postby adeshpande » Thu Jul 03, 2014 8:38 pm
I am pretty new to Parallella so these might be pretty simple questions that I'm asking so bare with me.
Do I connect all of the cables into a laptop's ethernet port, USB port, HDMI port, etc? (I think this is called using it as an embedded device)
Or do I connect all of the cables into a separate monitor, a separate mouse, an ethernet outlet in the room, etc? (I guess this is called a standalone device)
Does the choice between either of these 2 options affect the installation procedure?
adeshpande
Re: Parallella as a Standalone or Embedded Device?
Postby Bikeman » Thu Jul 03, 2014 8:42 pm
The Parallella is meant to be used "stand-alone".
HB
Bikeman
Postby adeshpande » Thu Jul 03, 2014 8:47 pm
Can it work as an embedded device as well?
adeshpande
Postby Bikeman » Thu Jul 03, 2014 9:35 pm
Bikeman
Postby CIB » Fri Jul 04, 2014 6:26 am
"Embedded device" usually means you're putting it into some sort of system, like a car. You can do that with the parallella, but I don't think that's related to your question.
CIB
Postby notzed » Fri Jul 04, 2014 8:37 am
I think what you're asking is whether you can use it headless - without keyboard, mouse, or monitor.
It can just be plugged into an ethernet hub or switch (or router which contains one of those) and accessed from a remote machine. The only thing to determine or configure is the IP address on your network. It should just boot from the sdcard up once power is applied.
This is how i've been using mine so far.
