Parallella Community • View topic - Programs on one or many cores?
Postby baseballguy » Mon Jul 14, 2014 8:01 pm
I was running some of the programs from this website (https://github.com/parallella/parallella-examples) like aobench, mandelbrot, and more. I was wondering if these programs are being excecuted on a single core or if they are utilizing all 16 cores. Is there a way to check the performance of each core?
baseballguy
Re: Programs on one or many cores?
Postby gceline » Mon Jul 14, 2014 9:35 pm
Most are running on 16 cores - take a look at the code to see how this is implemented
Graham
Adapteva
gceline
Postby baseballguy » Mon Jul 14, 2014 11:04 pm
Sorry, I'm kind of new to this parallel programming. What kind of things should I look for in the code to indicate that they are using more than one core?
baseballguy
Postby baseballguy » Mon Jul 14, 2014 11:26 pm
Also, is there any way to limit the number of cores used? For example, I want to compare a program running with only 4 cores as opposed to 16. Is that possible?
baseballguy
Postby greytery » Tue Jul 15, 2014 12:32 am
Yep. Just check the SDK manual. There's a section in e-loader on 'workgroups', which allows you to load the programs on to a specific set of cores.
Not that I've tried it yet :(
Postby shodruk » Tue Jul 15, 2014 2:26 am
Postby baseballguy » Tue Jul 15, 2014 1:28 pm
Thanks for the reply. I appreciate it. I tried to change the number of cores like you said. I saved it,
https://fbcdn-sphotos-h-a.akamaihd.net/ ... 14d9c68337
and tried running it again but I didnt see a change in the performance or anything. Is there a way to see the "statistics" as in the resolution, frames, iterations, etc like in your video.
https://www.youtube.com/watch?v=hFWIC3RF0f8
baseballguy
Postby baseballguy » Tue Jul 15, 2014 1:38 pm
I just realized that there are now two host.c files
https://fbcdn-sphotos-h-a.akamaihd.net/ ... 6ae732df3c
baseballguy
Postby 9600 » Tue Jul 15, 2014 2:03 pm
Postby baseballguy » Tue Jul 15, 2014 2:26 pm
Does anyone know what the problem is?
I have a feeling is has something to do with host.c and host.c~.
https://fbcdn-sphotos-h-a.akamaihd.net/ ... 95b473d789
Every time I edit one of the files to try to change the cores, another file with the same name with an added tilde is created (I did the same with aobench)
https://fbcdn-sphotos-h-a.akamaihd.net/ ... 0fc87521a2
I viewed the contents of both files and found the the file WITHOUT the tilde had the modified cores (1) but the one WITH the tilde had the same number of cores as in the beginning (16)
baseballguy
