Cannot boot from SD-Card with headless configuration
Postby yildizabdullah » Tue Aug 05, 2014 9:23 am
My board SKU number is A101020.
I use SanDisk Ultra microSDHC 8GB as SD card. System boot log is attached below.
parallella_boot_log.txt
(11.77 KiB) Downloaded 302 times
Last edited by yildizabdullah on Tue Aug 05, 2014 4:12 pm, edited 1 time in total.
yildizabdullah
Re: Cannot boot from SD-Card with headless configuration
Postby yildizabdullah » Tue Aug 05, 2014 10:48 am
Actually, I've found that a similar problem and its solution had been discussed before at
http://forums.parallella.org/viewtopic.php?f=48&t=1353.
You can find ajtravis's solution at http://forums.parallella.org/viewtopic.php?f=48&t=1353&hilit=plymouth&start=30#p9591.
yildizabdullah
Postby yildizabdullah » Tue Aug 05, 2014 12:34 pm
I've only changed the property bootargs as
- bootargs = "console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait devtmpfs.mount=0";
+ bootargs = "console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait";
What is the point of removing devtmpfs.mount=0 to log in?
yildizabdullah
