Parabuntu 2018.11.20
Postby Min » Sat Nov 24, 2018 7:36 pm
Upgrade to Ubuntu Base 18.04 LTS. e-SDK works on Parallella board.
No desktop environment for hdmi version. epython seems not working.
Other than these, it's almost the same as Parabuntu 2016.11.1.
https://github.com/xuminready/parabuntu/releases/latest
Min
Re: Parabuntu 2018.11.20
Postby zmc » Tue Dec 04, 2018 8:35 pm
Hey, that's great news! Have you built and ran the epiphany examples and test programs?
zmc
Postby Min » Wed Dec 05, 2018 7:05 am
zmc wrote:Hey, that's great news! Have you built and ran the epiphany examples and test programs?
Yes, it works. It's the same Linux kernel and FPGA bit file as Parabuntu 2016.11.1.
I may able to update Linux kernel in next few weeks. Can any body update FPGA design and e-SDK???
Min
Postby zmc » Wed Dec 05, 2018 7:52 pm
What needs to happen to the e-SDK? I thought you said all the examples and tests compile and run?
zmc
Postby Min » Thu Dec 06, 2018 5:29 am
zmc wrote:What needs to happen to the e-SDK? I thought you said all the examples and tests compile and run?
The example works. The e-gcc is based on gcc 5. I think it will be cool if it is updated.
Min
Postby zmc » Thu Dec 06, 2018 5:51 pm
Last entry in the changelog for e-gcc was on 2016-10-27 by Ola Jeppsson. I'm on gcc-7 here. I would imagine porting the epiphany code up two major versions of gcc would be quite a project. Maybe Ola could shed some light on what might need to be done.
zmc
