Parallella Community • View topic - High temperature causes bus error
Postby wiegmink » Mon Mar 13, 2017 11:38 am
Hi all,
I'm using the Parallella Embedded (Zynq 7020) with a heatsink mounted to constantly compute some algorithm. All 16 cores are kept busy, the Zynq PS feeds new data, collects results, and routes it to a network destination. After a while (5 minutes or so) a bus error occurred. At first I thought it was related to a possible memory conflict (gdb showed that the error occurred at e_read or e_write), but the message log showed the following:
[243461.989088] epiphany_vm_fault: Temperature outside operating range. Sending SIGBUS to process mainthread.elf (pid: 3426)
- Is it indeed so that a high temperate causes a bus error (the message is pretty clear, it's for my own peace of mind)?
- Which component is getting too hot (Zynq or Epiphany)?
- What is the threshold temperature?
- And finally again for my peace of mind, could a simultaneous read/write from the Zynq PS and a Epiphany core ever cause a memory conflict?
I added a small fan, and now it is already running for quite some time. So it seems clear.
I'm new to the forum, I don't think I found the answers somewhere else (I did search, but you never know).
Klaas
Klaas
wiegmink
Re: High temperature causes bus error
Postby jar » Mon Mar 13, 2017 2:01 pm
The Zynq is causing this. There is a thermal daemon running that can be configured in /etc/default/parallella-thermald if you want to void the warranty.
I picked up a couple of the recently and they've kept the Zynq well below the default limit and look much nicer. Though, I used the "heatsink hack" described here: https://parallella.org/forums/viewtopic.php?f=11&t=3928
Your fan setup should work now and prevent the thermal daemon from shutting the board down.
Postby wiegmink » Tue Mar 14, 2017 8:19 am
Thanks jar. I don't want to void the warranty, I just didn't make the connection between the bus error and overheating of the Zynq.
Klaas
wiegmink
