Google Summer of Code 2016
gsoc2016-sun-373x373
[UPDATE 3/8/2016  We were not accepted into GSOC, but the Fossi Foundation has graciously agreed to take us under their wings.  We will be accepting applications for the RISC-V and SDR projects]
We are applying to 2016 Google Summer of Code as a mentoring organization.  Below you will find a list of initial project ideas. If you are interested in becoming a project mentor or if you are an interested student please don’t hesitate to reach out. These are just ideas, once accepted as an organization we are open to any and all suggestions.
Learn more about Google Summer of Code
SCHEDULE
  • 19 February: Mentoring organization application deadline.
  • 29 February: List of accepted mentoring organizations published on the Google Summer of Code 2016 site.
  • 25 March: Student application deadline.
  • 22 April: accepted student proposals announced on the Google Summer of Code 2016 site.
  • 23 May: Students begin coding for their Google Summer of Code projects; Google begins issuing initial student payments provided tax forms/students are in good standing
  • 20 June: Mentors and students can begin submitting mid-term evaluations.
  • 27 June: Mid-term evaluations deadline; Google begins issuing mid-term student payments provided passing student survey is on file.
  • 15-23 August: Final week: Students tidy code, write tests, improve documentation and submit their code sample. Students also submit their final mentor evaluation.
  • 30 August: Final results of Google Summer of Code 2016 announced
PROJECT IDEAS (through Fossi)
Port RISC-V core to Parallella
Summary: The RISC-V is an exciting new open source processor architecture founded at UC Berkeley. A test environment has been created for the Zynq based Zedboard development platform. Given that there are over 10,000 Parallellas in the field in 75 countries and 200 universities, it would be a great services to computer architecture researchers if there was a ready to run reference implementation of the RISC-V rocket core running in the Zynq FPGA on the open source Parallella board
Link: https://github.com/ucb-bar/fpga-zynq
Language: Verilog, C, Chisel
Mentor: “Andreas Olofsson” andreas@adapteva.com
Create a Parallella acceleration framework for GNU radio
Summary: GNU radio is an immensly powerful framework for software defined radio, but it’s only as good as its built in hardware support. Currently, there is support for SIMD, GPUs, and FPGAs, but there is no support for manycore array accelerators like Epiphany.The project involves creating the equivalent of the following accelerator (done in an FPGA) for the Epiphany manycore accelerator. All code should be written in “high level” C to maximize portability between manycore architecture. Reference: https://gnuradio.org/redmine/projects/gnuradio/wiki/Zynq/35
Language: Python/C
License: GPL/MIT
NOTE: The project ideas have been put on hold.
Extend PAL library with more advanced vision functions
Summary:  The Parallel Architectures Library (PAL) is a compact C library with optimized routines for math, synchronization, and inter-processor communication. Any sane and informed person knows that the future of computing is massively parallel. Unfortunately the energy needed to escape the current “von Neumann potential well” seems to be approaching infinity. The legacy programming stack is so effective and so easy to use that developers and companies simply cannot afford to choose the better (parallel) solution. To make parallel computing ubiquitous our only choice is to rewrite the whole software stack from scratch, including: algorithms, run-times, libraries, and applications. The goal of the Parallel Architectures Library project is to establish the lowest layer of this brave new programming stack. The We have started this effort at  Currently the library contains a fair number of simple functions as a start, but to make it really useful another level of complexity is needed to more closely match OpenCV (generally considered the standard in the field).  The goal is to implement some of the most useful higher level image processing functions. The kernels should  be implemented as single threaded code and architecture agnostic.
Link: https://github.com/parallella/pal
Language: C
License: Apache
Mentor: “Ola Jeppsson” ola@adapteva.com
Implement software caching on Epiphany
Summary: Hardware caching wastes significant energy, is non-deterministic, and scales poorly to thousands of cores. Epiphany represents a class of architecture that includes closely coupled memory instead of automatic hardware caching to save power and area. The challenge with these types of processors is that the developer (or a program) must manage program and data memory.  Epiphany and other similar architectures would benefit greatly from having an open source reference implementation for doing effective “per function” software caching. An initial prototype has been created here:
Link: https://github.com/adapteva/epiphany-sdk/wiki/Software-caching
Language: C/assembly
License: GPL
Create a BLAS code generator for manycore processors
Summary: The BLAS library is a corner stone of many scientific computing applications. Every hardware vendor generally implements proprietary highly tuned implementations. Currently there is no known open source implementation for manycore RISC type architectures (like Epiphany).  Optimized “hard coded” open source routines have been written for the Epiphany and there is even an MPI implementation, but there is no code base currently available that scales with a large number of cores (like 1,000). The generator should be built on top of the PAL library and take N (number of points) and M (number of cores) as arguments to generate code that can be scheduled on a very large 2D array of cores.
Language: C
License: Apache 2.0
Create an FFT code generator for manycore processors
Summary: The FFTW library (and equivalent libraries from hardware libraries) is a corner stone of all signal processing applications.  Currently there is no known open source implementation for manycore RISC type architectures (like Epiphany).  Optimized “hard coded” open source routines have been written for the Epiphany and there is even an MPI implementation, but there is no code base currently available that scales with a large number of cores (like 1,000). The generator should be built on top of the PAL library and take N (number of points) and M (number of cores) as arguments to generate code that can be scheduled on a very large 2D array of cores.
Language: C
License: Apache 2.0
Create a 4,096 core Parallella board
Summary:  When it comes to algorithm scaling, “the proof is in the pudding.”  Simulation is a good start, but only if the simulator is cycle accurate. Actually proving the performance scaling requires real hardware. Commercial GPUs are available that supports launching thousands of parallel threads, but there is not a good hardware reference platform for 2D array architectures. The Epiphany chip currently in existence are based on 65nm technology and unfortunately only have 16 cores. Fortunately, the Epiphany devices include chip to chip links, allowing the devices to scale up to thousands of cores on single board.  If built, such an open source development platform would be a great tool for researchers interesting in testing scalability of cutting edge parallel algorithms.
Link: https://github.com/parallella/parallella-hw/tree/master/parallella-4k/docs
Language: Schematic entry, PCB design
License: MIT
[An interesting project, but clearly not “code” so probably not well suited for Google Summer of CODE. We will find some other way to support this development]
