Sharing your computer's Wifi connection with Parallella
Postby aolofsson » Thu Mar 20, 2014 12:38 am
This is a nice trick that I learned from some clever folks at the Eclipsecon hackathon. Turns out that it's really easy to share your internet connection with the Parallella using Ubuntu without needing to use a router. Here's what you need to do:
On laptop:
-Run a recent Ubuntu (I run 13.10)
-In the network-manager, edit connections and create a connection called "shared wifi connection"
-Edit that connection and in the ipv4 tab, select "shared to other computers".
-Connect an ethernet cable from your computer to the Parallella
-After being connected to the internet using wifi, clock on your new "shared wifi connection"
There are lots of posts explaining this further, here is one:
http://askubuntu.com/questions/359856/u ... h-ethernet
http://askubuntu.com/questions/359856/s ... h-ethernet
On Parallella:
1.) Connect the parallella with serial cable to your computer (or use a keyboard/mouse/hdmi screen to interact directly).
2.) Check that network interface definitions looks like the following.
/etc/network/interfaces should have the following
auto eth0
iface eth0 inet dhcp
You may also need to remove the following file and reboot:
/etc/udev/rules.d/70-persistent-net.rules
3.) At terminal, reset the interface to allow laptop to assign IP address to the board:
sudo ifdown eth0
sudo ifup eth0
4.) Verify IP address using ifconfig/ping internet.
Re: Sharing your computer's Wifi connection with Parallella
Postby shodruk » Fri Mar 21, 2014 11:00 am
That's magical! :o
Postby nmalinoski » Thu Apr 24, 2014 2:14 am
nmalinoski
Postby shodruk » Thu Apr 24, 2014 12:52 pm
Postby Dyzav » Sat May 16, 2015 11:56 pm
With Headless Parallella
Laptop:
-Running on Linux Mint 17.1 64-bit
-network-manager same as Ubuntu ( Steps 1.- 5. http://askubuntu.com/questions/359856/u ... h-ethernet)
-for finding IP addresses Installed ipscan ( http://www.upubuntu.com/2013/01/install ... pa-in.html)
Parallella desktop board :
-Connecting:
sudo ssh -XC parallella@IP( e.g.192.168.0.15)
-Running on Ubuntu 14.04 Parallella ( Zynq7010) headless image ( Jan 30th 2015 release, 515MB)
rm /etc/udev/rules.d/74-persistent-net.rules ( removing.. in my case the number is 74 not 70, don't know if it helped or not)
-tried:
sudo ifdown eth0
-Installing network manager ( https://help.ubuntu.com/community/NetworkManager)
sudo start nm-connection-editor
-Then ( Steps from 6. http://askubuntu.com/questions/359856/u ... h-ethernet)
-All works well
Dyzav
Postby aolofsson » Tue May 19, 2015 2:21 am
Very nice! Thanks for sharing!
Postby dennis » Fri Jan 22, 2016 4:02 am
dennis
