poor static memory access
Postby notzed » Thu Mar 27, 2014 12:54 am
Re: poor static memory access
Postby amylaar » Tue Apr 01, 2014 5:34 pm
The following seems to help, particularly with -fno-common; however, does it cause performance regression for other code?
Index: common/config/epiphany/epiphany-common.c
--- common/config/epiphany/epiphany-common.c (revision 205586)
+++ common/config/epiphany/epiphany-common.c (working copy)
@@ -39,6 +39,8 @@ #define TARGET_DEFAULT_TARGET_FLAGS \
static const struct default_options epiphany_option_optimization_table[] =
{ OPT_LEVELS_1_PLUS, OPT_fomit_frame_pointer, NULL, 1 },
+ /* Enable section anchors by default at -O1 or higher. */
+ { OPT_LEVELS_1_PLUS, OPT_fsection_anchors, NULL, 1 },
{ OPT_LEVELS_NONE, 0, NULL, 0 }
Index: config/epiphany/epiphany.c
--- config/epiphany/epiphany.c (revision 205586)
+++ config/epiphany/epiphany.c (working copy)
@@ -145,6 +145,13 @@ #define TARGET_ASM_CAN_OUTPUT_MI_THUNK \
hook_bool_const_tree_hwi_hwi_const_tree_true
#define TARGET_ASM_OUTPUT_MI_THUNK epiphany_output_mi_thunk
+/* ??? we can use larger offsets for wider-mode sized accesses, but there
+ is no concept of anchors being dependent on the modes that they are used
+ for, so we can only use an offset range that would suit all modes. */
+#define TARGET_MAX_ANCHOR_OFFSET 2047
+/* We further restrict the minimum to be a multiple of eight. */
+#define TARGET_MIN_ANCHOR_OFFSET -2040
#include "target-def.h"
#undef TARGET_ASM_ALIGNED_HI_OP
@@ -763,6 +770,11 @@ epiphany_rtx_costs (rtx x, int code, int
*total = COSTS_N_INSNS (1);
return true;
+ case PLUS: case MINUS:
+ if (outer_code == SET)
+ *total = 0;
+ return false;
default:
return false;
@@ -2003,7 +2015,7 @@ #define REG_OK_FOR_BASE_P(X) \
&& LEGITIMATE_OFFSET_ADDRESS_P (mode, XEXP ((x), 1)))
return true;
if (mode == BLKmode)
- return true;
+ return epiphany_legitimate_address_p (SImode, x, strict);
return false;
Index: config/epiphany/epiphany.h
--- config/epiphany/epiphany.h (revision 205609)
+++ config/epiphany/epiphany.h (working copy)
@@ -942,4 +942,15 @@ extern rtl_opt_pass *make_pass_resolve_s
#define ASM_DECLARE_FUNCTION_NAME(FILE, NAME, DECL) \
epiphany_start_function ((FILE), (NAME), (DECL))
+/* This is how we tell the assembler that two symbols have the same value. */
+#define ASM_OUTPUT_DEF(FILE, NAME1, NAME2) \
+ do \
+ assemble_name (FILE, NAME1); \
+ fputs (" = ", FILE); \
+ assemble_name (FILE, NAME2); \
+ fputc ('\n', FILE); \
+ while (0)
#endif /* !GCC_EPIPHANY_H */
amylaar
Postby notzed » Wed Apr 02, 2014 1:45 am
ta, i'll try that in the following days and let you know how i fare.
Postby notzed » Wed Apr 02, 2014 12:39 pm
Postby amylaar » Thu Apr 03, 2014 2:32 pm
t1068-diff-2.txt
(6.04 KiB) Downloaded 1401 times
amylaar
Postby notzed » Fri Apr 04, 2014 2:51 am
Postby amylaar » Fri Apr 04, 2014 3:31 am
amylaar
Postby amylaar » Fri Apr 04, 2014 7:03 am
I found that my cost correction for postreload actually messed things up for combine and other passes - I have to test for SET in code, not
outer_code.
That done, postreload doesn't do anymore what we'd want it to do. That's a hard problem because now we got loads of symbols that we
want to change into adds, and the latter cause flag clobbers. move2add is not prepared to handle flag clobbers, so we'd first have to add
that facility there.
amylaar
Postby notzed » Fri Apr 04, 2014 11:56 pm
Postby timpart » Sat Apr 05, 2014 8:41 am
