movts/movfs vs ldr/str: parmeterising functions
Postby notzed » Fri Mar 28, 2014 1:49 pm
It was alluded to in another thread (the object recognition one) that movts/movfs just go through the external mesh. Are they physically the same then as simply issuing a ldr/str via a global memory address to the current core? Specifically, in terms of performance (assuming all else being equal such as the target address is already in a register).
The reason I ask is that having the specific register names in movts/movfs make parameterising functions a bit bulky because it requires specific code for each case. The mainly affects dma routines. Because the timer stuff uses different bits of the config register it doesn't help much there.
Re: movts/movfs vs ldr/str: parmeterising functions
Postby aolofsson » Sat Mar 29, 2014 3:48 pm
There are some subtle differences in the hardware, but in general..YES you can just use the global address:
The exception is the STATUS and CONFIG register which must be accessed through the MOVTS/MOVFS instructions.
Example:
https://github.com/adapteva/epiphany-li ... reg_read.c
Postby notzed » Mon Mar 31, 2014 9:04 am
Ok interesting, thanks again.
