First time Parallella booting
Postby speccy » Thu May 08, 2014 1:34 pm
Hi, I did the first step to put the Linux image on the SD card and powered the board.
I don't have a Micro HDMI adapter at the moment, is it possible to log in with SSH right now? Is there a static IP assigned to the Parallella or its DHCP? I dont have a router, I want to plug the board directly in my laptop, is it possible to do so?
Thanks for your help
speccy
Re: First time Parallella booting
Postby 9600 » Thu May 08, 2014 2:41 pm
Default configuration uses DHCP.
You should be able to connect it direct to your laptop, with a crossover network cable. And I believe that Windows and Mac both have some form of "connection sharing" functionality, whereby they will run a DHCP server and act as a firewall/NAT so that another machine can share the Internet connection. E.g. laptop connecting out over WiFi and Parallella connecting to it over Ethernet.
Postby FHuettig » Thu May 08, 2014 6:33 pm
Postby shodruk » Fri May 09, 2014 5:24 am
Postby rec » Sat May 10, 2014 11:27 pm
rec
Postby ZenoArrow » Wed May 14, 2014 8:25 am
This guide is for the Raspberry Pi, but I imagine the networking tips are just as relevant to the Parallella:
ZenoArrow
Users browsing this forum: No registered users and 37 guests
