make results in undefined reference to e_reset_core
Postby donaldleslie » Sat May 10, 2014 12:04 am
As a first test i went to the parallella-examples directory.
The executable xtemp works fine
If I try another e.g. mandelbrot and run make I get.
gcc -O3 host.c -o main -I /opt/adapteva/esdk/tools/host/include -L /opt/adapteva/esdk/tools/host/lib -le-hal -lrt
/tmp/ccD1CvOM.o: In function `main':
host.c:(.text.startup+0x100): undefined reference to `e_reset_core'
make: *** [main] Error 1
What am I missing?
donaldleslie
Re: make results in undefined reference to e_reset_core
Postby ticso » Sat May 10, 2014 12:27 am
I had been running into this myself.
You need some environments variables to be set, which are defined for linaro user, but not for root.
ticso
Postby holgt » Sat May 10, 2014 6:42 am
For me it also applies as user linaro ..., i made the roots via sudo tar -xvf ubuntu-lxde-14.03.06-rootfs.tar.gz -C /path/to/mmc/rootfs,
maybe it is an issue of ubuntu-lxde-14.03.06-rootfs.tar.gz not making the environment vars ...
holgt
Postby shodruk » Sun May 11, 2014 11:28 am
The source code bundled with the ubuntu-lxde-14.03.06-p16g1.img is obsolete.
Get the latest source code from GitHub.
https://github.com/parallella/parallella-examples
