Request for VESA mount for the acrylic case
Postby nmalinoski » Sat May 10, 2014 6:44 pm
Could Adapteva please produce a VESA mount add-on for those with the acrylic cases? All we need is a new, larger top plate with 100mm x 100mm-spaced mounting holes, a set of rubber nubs, and a set of appropriately-sized screws.
By replacing the top plate, a user would still have his/her choice of the Parallella logo plate on the outside. The end-pieces, which are designed to fit neatly around the ports but have the extended leg portions, would only have to be swapped out if the bottom plate was being replaced. The only downside I can see is that the green LED would then be facing inward, but that's hardly a big deal.
nmalinoski
Users browsing this forum: No registered users and 37 guests
