Benefits of a serial cable, which to buy and how to use it.
Postby Gravis » Wed May 14, 2014 3:43 pm
USB serial monitor cable
Re: Benefits of a serial cable, which to buy and how to use
Postby greytery » Wed May 14, 2014 4:30 pm
Thanks Gravis.
For those in the UK try :
@ £9.99. Handy if you are passing one of their shops.
or
@ £6.99
Inc. VAT, plus post.
I can confirm that it works with a Raspberry Pi, but will pay attention to the notes from Gravis when fitting to the Parallella.
There are a few tutorials on installation on Windows, including pointers to the necessary drivers, and connection to Pi. Most of these should transfer easilly.
Postby over9000 » Wed May 14, 2014 8:52 pm
over9000
Postby CIB » Thu May 15, 2014 5:19 am
Thanks, this will be useful for me, since I have no monitor to plug the parallela into.
CIB
Postby jaor » Fri Jul 04, 2014 8:23 pm
Hi, can you update your post with the following information (I'm a newbie, and was struggling a bit with it ;) ):
I am using PL2303HX based converter. As of this, I had to connect wires by myself, so there was no colors by default.
According to this post (viewtopic.php?f=10&t=845&start=20) you have to connect RX-TX and TX-RX and GND-GND.
Thanks for your post, it helped me a lot with debugging!
jaor
Postby daniel_dbb » Sat Sep 10, 2016 5:53 pm
I am using Adafruit FT232H Breakout board to communicate at TX/RX port with Parallella.
After Power ON I get:
U-Boot 2012.10-00003-g792c31c (Jan 03 2014 - 12:24:08) // <--- First Line
... (see more below)
Starting kernel ...
Uncompressing Linux... done, booting the kernel. // <--- Last Line
and after last line nothing more
No Promt for interaction with Parallella!
Why?
Does anybody expirienced same problem with Adafruit USB-UART Adapter?
Bye,
Daniel
I2C: ready
DRAM: 992 MiB
WARNING: Caches not enabled
MMC: SDHCI: 0
SF: Detected N25Q128 with page size 64 KiB, total 16 MiB
In: serial
Out: serial
Err: serial
Net: zynq_gem
Hit any key to stop autoboot: 0
Configuring PL and Booting Linux...
Device: SDHCI
Manufacturer ID: 1b
OEM: 534d
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 59.6 GiB
Bus Width: 4-bit
reading parallella.bit.bin
2083744 bytes read
reading uImage
4468792 bytes read
reading devicetree.dtb
8607 bytes read
## Booting kernel from Legacy Image at 03000000 ...
Image Name: Linux-3.12.0-g0bc9c3a-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4468728 Bytes = 4.3 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
Booting using the fdt blob at 0x02a00000
Loading Kernel Image ... OK
OK
Loading Device Tree to 1fffa000, end 1ffff19e ... OK
Starting kernel ...
daniel_dbb
Postby sebraa » Sun Sep 11, 2016 8:43 pm
By default, the serial console is disabled in new images.
Postby olajep » Mon Jan 09, 2017 3:33 pm
