Intermingling data with code
Postby timpart » Wed Jan 16, 2013 9:42 pm
Is it safe to write a sequence like this?
.align 8
B label ; 32 bit version
.word arbitrary data
or even
.align8
JALR R42 ; go somewhere (but don't come back!) R14 handily points to arbitrary data after jump
The pipeline decodes the instructions (stage 3) before executing them (stage 5). If the arbitrary data contained a bit pattern that was an invalid instruction would some kind of fault be generated? If it only generates the fault when instruction reaches stage 5 presumably all would be OK. If at stage 3, it wouldn't.
If a fault does get generated would this work?
.align8
JALR R42 ; go somewhere (but don't come back!) R14 handily points to word before arbitrary data after jump
NOP ; 16 bits each
NOP
Thanks in advance,
