E64G401 clock speed?
Postby booth » Tue May 20, 2014 12:01 pm
I wonder why the clock speed of E64G401 is limited to 800 MHz. Is this because of the latency of the FPU (fused multiply-add) inside each core or is it to preserve power?
booth
Re: E64G401 clock speed?
Postby aolofsson » Tue May 20, 2014 4:24 pm
Static power dissipation is a HUGE problem in advanced processes like 28nm, so the transistors are made quite slow. The main critical path was on chip SRAM access.
Best regards,
Postby booth » Tue May 20, 2014 8:10 pm
booth
Postby aolofsson » Wed May 21, 2014 6:34 am
We don't have a spreadsheet or "power simulator", but please look at the following video of the epiphany-IV. It shows the power consumption under different load conditions. (Including the code that ran).
https://www.youtube.com/watch?v=B9fpoJHUX0o
Postby booth » Wed May 21, 2014 2:19 pm
Thanks for the Information,
I was suprised that the SRAM access takes longer than the Floating point multiplier though.
booth
Postby aolofsson » Wed May 21, 2014 4:37 pm
That's because SRAM access needs to be single cycle and the floating point unit is spread out over 4 clock cycles.
