Can not SSH into board
Postby pietervdvn » Wed May 28, 2014 8:45 pm
I bought two parallella's. As I'm still missing the HDMI-cables, I decided to try them out via ssh.
One of the boards works like a charm and boots fine with a SD-card. I did setup a static IP for it and I can ssh into it right away.
I can't connect to the other board however. Anyone a bright idea?
(Tested with the same SD-card, identical power line...)
pietervdvn
Re: Can not SSH into board
Postby aolofsson » Wed May 28, 2014 9:11 pm
Not sure..but sharing SD cards can be problematic since the mac-ids are different. Not sure about your setup, so hard to know exactly.
Did you try deleting the following file from the SD card before inserting the SD card in your second board?
/etc/udev/rules.d/70-persistent-net.rules
