Using SDK version 5.13.09.10
Postby castan » Fri May 30, 2014 1:28 pm
castan
Re: Using SDK version 5.13.09.10
Postby ysapir » Fri May 30, 2014 11:58 pm
When everything is installed correctly, you should be able to use "e-gcc" instead of "epiphany-elf-gcc". I'd start with verifying this.
Postby castan » Sun Jun 01, 2014 10:00 am
castan
Postby ysapir » Wed Jun 04, 2014 2:19 am
Postby ysapir » Wed Jun 04, 2014 2:23 am
WAIT! Are you trying to compile the host-side or the device side application? Note that the host side build uses the ARM toolchain. If you build on the Parallella board, simply use "gcc". If on your PC, using the cross-build tools, use "a-gcc".
Postby castan » Sat Jun 07, 2014 5:53 pm
castan
