EDIMAX EW7811Un
EDIMAX EW7811Un
Postby oakeley » Sat May 31, 2014 9:31 pm
oakeley
Re: EDIMAX EW7811Un
Postby 9600 » Sun Jun 01, 2014 8:26 pm
I'd suggest building a new kernel with support for that hardware enabled. To get started see Shodruky's post:
viewtopic.php?f=48&t=1230
During the make menuconfig stage I think you will need to enable the rtl8192cu driver.
Re: EDIMAX EW7811Un
Postby coffeespoons » Thu Jun 05, 2014 8:58 pm
coffeespoons
Re: EDIMAX EW7811Un
Postby ArunD » Fri Jun 12, 2015 8:48 pm
Hello!
After some debugging of USB issues I was able setup Edimax USB wifi adaptor to connect to my Wifi network. However, I notice t hat for the first three or so minutes I notice that the connectivity is not 100%, e.g. ssh will not connect, and ping will show 50% or so packet loss. After three minutes the packet loss is gone, ssh just works fine. A few times of testing confirms this.
The wifi environment does not seem to the issue because I have two other computers (a desktop and a laptop) next to it, and have been ok for years. The USB setup may be questionable, and I have posted the question .
So, is the USB stack in question? How could I characterize this problem better towards a resolution?
ArunD
Re: EDIMAX EW7811Un
Postby piotr5 » Fri Jun 12, 2015 10:37 pm
can't say for sure, but on raspberry pi there were problems because some usb-devices failed to work. the reason was that not enough power was provided. maybe also this device consumes too much power in the beginning? afaik wifi devices know some energy-saving modes, if the distance is small. so, thanks for giving us the info on which device consumes too much power...
Re: EDIMAX EW7811Un
Postby ArunD » Sat Jun 13, 2015 8:19 am
ArunD
Re: EDIMAX EW7811Un
Postby ArunD » Sun Jun 14, 2015 8:51 am
The reliability of the Edimax USB wifi adapter connected to the Parallella via a USB hub seems to be related to the USB. In my USB side setup I added a USB-IDE bridge with a IDE drive connected to it. With this the packet loss on the wifi seems worse. Also, while the setup is functional I poweroff and unplug the IDE adaptor on the USB, and the pings to the wifi adapter resume to 100% immediately.
Perhaps it's the hub, perhaps it's the load on it.
ArunD
Re: EDIMAX EW7811Un
Postby ArunD » Sun Jun 14, 2015 12:39 pm
ArunD
Re: EDIMAX EW7811Un
Postby 9600 » Sun Jun 14, 2015 1:04 pm
Re: EDIMAX EW7811Un
Postby ArunD » Mon Jun 15, 2015 3:29 pm
ArunD
