HDMI input
HDMI input
Postby costa » Fri Jun 06, 2014 7:42 am
Hello! It would be interesting to have a video input for parallela in order to do real-time video processing. Is it possibile to re-program the Zynq in order to manage it? Or is it possible only through a daughter board?
Leo
costa
Re: HDMI input
Postby 9600 » Fri Jun 06, 2014 12:51 pm
You can obviously easily attach a USB or Ethernet camera.
If you'd like a more direct / lower latency connection you could attach a camera via the PEC_FPGA expansion connector, which would give you up to 48x single-ended or 24x differential GPIOs with a Z-7020, with interface logic implemented in the FPGA.
Re: HDMI input
Postby dpavlin » Fri Jun 06, 2014 1:38 pm
Looking at datasheet of TPD12S016PWR (which is in-between Zynx and HDMI connector) it seems to me that it should be possible to create HDMI input. I started looking at it to think whether it will be possible to use HDMI breakout board as alternative to GPIO breakout board, but I still don't have anything to report on that topic :-)
If anybody want to pursue this, there is HDMI implementation within Bunny's NeTV which might be interesting:
http://www.kosagi.com/w/index.php?title ... chitecture
https://github.com/bunnie/netv-fpga
if for nothing else, because it has legal implementation of HDCP inside it
https://github.com/bunnie/netv-fpga/tre ... ease1/hdcp
(NeTV doesn't decode content received over HDMI, it just init cipher so it can overlay data over existing HDMI stream).
dpavlin
Re: HDMI input
Postby FHuettig » Fri Jun 06, 2014 4:14 pm
