Problems with serial login and possibly booting
Postby asic » Sat Jun 07, 2014 11:54 pm
asic
Re: Problems with serial login and possibly booting
Postby timbat » Sat Jun 14, 2014 4:25 am
I have had the same problem with /sys/fs/selinux mount. Have you made any progress ?
timbat
Postby asic » Sat Jun 14, 2014 6:06 am
asic
Postby 9600 » Sat Jun 14, 2014 2:51 pm
Postby greytery » Sun Jun 15, 2014 10:50 am
Postby shodruk » Sun Jun 15, 2014 11:10 am
My Parallella has a problem with boot reliability by enabling serial console.
Adapteva should include both of the dtb files (with serial console, without serial console) in the kernel tarball, so that we can switch them easily.
e.g.
sudo cp devicetree.uart.dtb devicetree.dtb
sudo cp devicetree.hdmi.dtb devicetree.dtb
(the default devicetree.dtb : without serial console version)
Postby shodruk » Sun Jun 15, 2014 1:16 pm
Postby shodruk » Sun Jun 15, 2014 2:01 pm
There are three different dtb files here.
HDMI-A, HDMI-B, Headless-B
md5sums:
https://github.com/parallella/parallell ... .02.06.tgz
[HDMI-A] 1ae97d40b13c27db49f4c287b84d5125 devicetree.dtb
viewtopic.php?f=10&t=1069#p7965
[HDMI-A] 1ae97d40b13c27db49f4c287b84d5125 devicetree-HDMI.dtb
[Headless-B] 0fc88783b4bd3a6d9881cdb560f8aaf2 devicetree-headless.dtb
http://downloads.parallella.org/boot/li ... 140603.tgz
[HDMI-B]7612890456dca87ecc2638c535b5997e devicetree.dtb
[Headless-B] 0fc88783b4bd3a6d9881cdb560f8aaf2 devicetree.dtb
[HDMI-A]
for old bitstream
UART enabled
devtmpfs disabled
[HDMI-B]
for new bitstream
UART disabled
devtmpfs enabled
[Headless-B]
for new bitstream
UART enabled
devtmpfs disabled
Postby hochopeper » Sun Jun 15, 2014 2:46 pm
Thanks for those instructions shodruk, I was going to play around with that later this week.
Should these variations of devicetree end up in here eventually https://github.com/parallella/parallella-linux-adi
I haven't got a linux system handy and can't be bothered firing my parallella up now (it's after midnight) so I haven't done a diff but I'm guessing this means that this - https://github.com/parallella/parallell ... 3f65cad205 is now out of date?
Chris
hochopeper
Postby greytery » Sun Jun 15, 2014 3:36 pm
Ditto - thanks for the instructions, shodruck.
You make it sound so easy :) I'll play around and move on.
It seems that you only really need the UART/USB for troubleshooting and/or setting up the headless system in the first place.
Once the network is in place the cable is going to be unplugged.
