paper on extended "double-single" precision
Postby notzed » Sat Jun 14, 2014 11:05 am
The paper ``Extended-Precision Floating-Point Numbers for GPU Computation'' by Andrew Thall may be of use for the epiphany.
It outlines some basic flops for a double-single format that I presume should be faster (and smaller) than a software-ieee-double library. All operations are decomposed into 32-bit flops so can run on hardware. It approximately doubles the mantissa accuracy but doesn't extend the exponent.
I downloaded it from here: http://andrewthall.net/papers/df64_qf128.pdf
Re: paper on extended "double-single" precision
Postby upcFrost » Sat May 27, 2017 11:28 pm
Actually it might worth trying to implement. I'll try probably, at least basic ops
upcFrost
Postby jar » Sun May 28, 2017 12:42 am
Return to Algorithms
