Node.js
Node.js
Postby fsanzv » Fri Jan 25, 2013 10:31 am
Is there any way to use the Epiphany cores to run Node.js applications? Maybe using each core as a node in a cluster?
I am very interested in use Parallella board as a tiny and powerfull server platform in Node.js.
Fernando
fsanzv
Re: Node.js
Postby 9600 » Fri Jan 25, 2013 11:05 am
Re: Node.js
Postby ChrisRus » Sat Mar 28, 2015 9:33 pm
I'm curious if anyone has revisited this since the OP. I haven't tried it but it would seem completely practical to run a Node.js process on the host A9 and use it as a gateway to the Epiphany (via a native extension to Node.js). In my scenario, the A9 would be heavily loaded with upstream socket management, JSON I/O normalization, and dispatch of code, program, and data to the Epiphany.
Guess I should just go try it and see how far I can get.
ChrisRus
Re: Node.js
Postby roborob » Fri May 29, 2015 10:48 pm
roborob
Re: Node.js
Postby 9600 » Sun May 31, 2015 1:42 pm
Not AFAIK.
Re: Node.js
Postby chrismatthieu » Sun Sep 20, 2015 10:45 pm
I just purchased a 16 core Parallella board. I was excited to build a node.js app that utilized all 16 cores but require('os').cpus().length returns 2. Any updates on actually using these cores with node.js?
chrismatthieu
Re: Node.js
Postby sebraa » Mon Sep 21, 2015 12:32 pm
Not yet. You'd need to extend the node.js interpreter to be able to utilize the Epiphany cores. I don't know enough about node.js to comment on whether this is feasible or not, given the (fast) memory limitation of the Epiphany.
Re: Node.js
Postby chrismatthieu » Sun Oct 18, 2015 5:00 pm
Running Node.js on the board while directing eval() javascript routines to the other cores would be sufficient. Would this be possible? Any guidance would be greatly appreciated.
chrismatthieu
