Connected 12 volt instead of 5 volt
Postby EN8lvVPyrXVsNved3pcP » Sun Jun 22, 2014 10:13 pm
My board was working perfectly and I was going to continue doing some experiments when I accidentally plugged in 12 volts instead of 5 volts to the power supply plug. Needless to say nothing works now except the fan keeps starting and stopping. There was no magic smoke released so its not obvious that any particular device might have blown. Is their any chance that I might be able to revive the board or is it a lost cause ? Any suggestion for trouble shooting would be appreciated. If their is no chance would it be possible to get an early order for a new board ? I waited almost 12 months for this one and I am so disappointed that I did this. I always double and triple check these things but don't you know it would happen to a difficult to replace piece of equipment :( :(
Re: Connected 12 volt instead of 5 volt
Postby Hrun » Mon Jun 23, 2014 7:58 am
Wow... The same happened to me, at around the same time as you posted this!
I cried so hard! :cry: (Then I proceeded to drink my secret stash of wine... Not sure what happened next.)
The board got really warm, but no smoke either. 1 of the LEDs (a green one) still works fine when I apply 5V now, but it doesn't register itself on the network.
Hrun
Postby sidda2020 » Mon Jun 23, 2014 8:43 am
Murphys' law worked here.. "if something can go wrong, it will"...
Its gone case man.. plan for another Parallella..I could spare one.. I stay in bangalore..
sidda2020
Postby tnt » Mon Jun 23, 2014 10:49 am
Well there is a couple of things that are definitely obliterated. Both USB PHYs and the HDMI PHYs are definitely destroyed. You might try to unsolder those, they might be preventing the rest from working. The TURBO_MODE buffer is also probably a goner.
the PMICs are also not rated for 12V operation, but they might just have survived, you can check the power rails. Also checking the board with a thermal camera might reveal what survived.
Postby EN8lvVPyrXVsNved3pcP » Tue Jun 24, 2014 5:29 pm
Thanks I will try and trouble shoot to see where the power stops. HRUN yes I definitely cried also. None of my LED's come on anymore but the Fan and the Unpowered USB hub keep cycling on and and off. sidda2020 I would be interested in buying one if you have an extra spare. There is no telling when new ones might be available. :) :) :)
Postby EN8lvVPyrXVsNved3pcP » Fri Jun 27, 2014 6:03 pm
Whooo !!!! So far have not been able to resurrect the board.. :oops: But the good new is I managed to get another ordered today so I will be even MORE careful in the future !!!!!! :mrgreen:
Postby Hrun » Fri Oct 24, 2014 4:06 pm
Hrun
Postby aolofsson » Fri Oct 24, 2014 5:45 pm
Well done!! And thanks for helping to verify what component actually breaks when you plug in a 12V supply! :D
Postby stoile » Wed Nov 19, 2014 4:02 pm
The same happened to me, too.
When I now connect my Parallela to 5V, the fan is working, the LED is green (not blinking) and the LEDs of the ethernet port are green and orange. I have the parallela from the Kickstarter Campaign. Any hints how I could check what got damaged and how to repair it?
stoile
Postby 9600 » Wed Nov 19, 2014 8:27 pm
I'm sorry to hear that :(
I'd start by checking out the different voltage rails and, given the experiences of the previous poster, I'd probably pay close attention to the ISL9307 voltage regulator. The .
Good luck!
