64 core is not available....alternatives....
Postby webmasterpdx » Wed Jun 25, 2014 12:58 am
Since the 64 core is not available, there is a competitive solution from NVIDIA with 192 cores and 365GFlops for $192.
It's programmable using CUDA (NVIDIA) and is available now....using the Tegra K1 processor.
http://nvidianews.nvidia.com/News/NVIDI ... s-ad8.aspx
....enjoy...
webmasterpdx
Re: 64 core is not available....alternatives....
Postby Bikeman » Wed Jun 25, 2014 9:12 am
Bikeman
Postby Gravis » Fri Jun 27, 2014 3:05 pm
One very big difference is that a "CUDA core" is just a FPU pipeline. This means there isnt any branching in a CUDA core but rather in the parent SMX processor. the SMX processor controls all the CUDA cores and has 64KB of memory to share. why does that matter? well, do you like branching or reading/writing data? because you wont be doing it very quickly. :D
here is the whitepaper about the Kepler architecture: http://www.nvidia.com/content/PDF/keple ... epaper.pdf
here is the SMX:
if you are primarily doing rendering then having tons of floating point pipelines is awesome. however, if you are making actual programs, you will need that branching, storing, loading and integer math which is not going to work well on this GPU.
Postby Bikeman » Fri Jun 27, 2014 11:14 pm
Bikeman
Postby Gravis » Sat Jun 28, 2014 12:01 pm
Postby mhonman » Sat Jun 28, 2014 4:58 pm
mhonman
Postby Bikeman » Sat Jun 28, 2014 6:57 pm
Bikeman
Postby Gravis » Sat Jun 28, 2014 9:59 pm
Postby Bikeman » Sat Jun 28, 2014 10:20 pm
You are free to suggest a different benchmark with which we could compare those two platforms.
HB
Bikeman
Postby Gravis » Sun Jun 29, 2014 3:27 am
