How to use Kinect with Parallella
Postby shodruk » Fri Jul 11, 2014 5:05 pm
Hi, I wrote a simple Kinect test program that can be run on Parallella.
Demo Video: http://youtu.be/cVTc5PzMpPg
Source Code: https://github.com/parallella/parallell ... inect_test
It uses only one eCore for fullscreen rendering, so we can use other 15 eCores to do something interesting.
Re: How to use Kinect with Parallella
Postby greytery » Fri Jul 11, 2014 6:10 pm
How about using the other cores to replicate the movements and have a full dance group? (different costumes, different depths, sideways movement, whooooo!) :)
You've done it again haven't you!!! :geek:
Well done.
Cheers
Postby shodruk » Sat Jul 12, 2014 6:23 pm
Thanks terry,
I want to implement a simple image recognition using other eCore.
But I have to learn more about it. :)
Postby 9600 » Sun Jul 13, 2014 1:09 pm
+1 and very cool indeed :) Now I want to get a Kinect so I can have a play myself.
Postby shodruk » Mon Jul 14, 2014 9:17 am
Thanks Andrew,
It's rather expensive but worth to buy.
Postby aolofsson » Mon Jul 14, 2014 9:35 am
all,
Before anyone runs out and buys a kinect, make sure you buy the right one. Not all of Kinects work with libfreenect. We made that mistake a 18 months ago. :D (at least that was the case back then...)
Postby shodruk » Tue Jul 15, 2014 2:31 am
Yes, you should buy a "Kinect for XBOX360", not a "Kinect for Windows" nor a "Kinect for XBOX One" to use libfreenect1.
Postby Pieter-Jan » Tue Nov 04, 2014 10:51 am
has anyone tried to get this running on the parallella? https://github.com/xxorde/librekinect
It seems a more solid/clean solution
Pieter-Jan
