test and quicktest mostly good
Moderator: dar
Postby nickoppen » Sat Jul 12, 2014 10:53 am
Hi dar,
I got COPRTHR via the pre-installed version that came with Ubuntu 14.04.
Reading through the primer I decided (as root) to run "make quicktest" and "make test" from /usr/local/browndeer/test. Most of the tests succeeded. There were some compile warnings which looked benign and some other output such as the OpenCL the available devices and their characteristics.
Is the the output you would expect at this stage? I assume that the installation on the 14.04 image was tested and what was installed is the best available?
Given that I am a complete linux ignoramus and have no hope of "fixing" anything, are there any tweaks that you recommend before starting to code?
nick
nickoppen
Re: test and quicktest mostly good
Postby nickoppen » Tue Jul 29, 2014 1:43 am
nickoppen
Postby nickoppen » Tue Jul 29, 2014 12:17 pm
nickoppen
Return to OpenCL
