can we port CMUcam5 code to Parallella = fastest vision
Postby freeenergy » Wed Jul 16, 2014 6:08 pm
hi
can we use CMUcam5 open source code on Parallella :)
CMUcam5 open source fast vision sensor 50fps vga
CMUcam5 have only two core 168mhz + 36mhz = 50fps vga fast vision sensor
Parallella have 16 core = fastest vision sensor :o
so can we port CMUcam5 source code to Parallella
what do you think
i don't know how to port it :x
freeenergy
Re: can we port CMUcam5 code to Parallella = fastest vision
Postby aolofsson » Sun Aug 03, 2014 5:47 pm
Are you suggesting replacing the nxp chip on the board? If so,then someone would need to build a camera daughter board and connect it to the Zynq FPGA logic. Otherwise, it seems possible to connect a USB cable, but then one might as well use a webcam? Sorry if I missed something (please correct me if that is the case).
http://www.cmucam.org/projects/cmucam5/ ... n_on_Linux
Postby Gravis » Sat Aug 09, 2014 2:49 pm
Postby freeenergy » Sat Aug 09, 2014 4:52 pm
freeenergy
