No /dev/epiphany device
Postby Pavel » Sun Jul 20, 2014 5:50 pm
I have a Parallella board.
I had problems with ubuntu-14.04-140611.img image so I switched to ubuntu-14.01-lxde-14.03.06.img.
I also use Linux kernel without HDMI support (“headless”).
I have built Epiphany SDK but when I try to use E-UTILS (e-reset, for example) I get an error like "/dev/epiphany not found" .
Actually I see no "/dev/epiphany" device in the filesystem.
What can be the issue?
Pavel
Re: No /dev/epiphany device
Postby 9600 » Sun Jul 20, 2014 7:39 pm
Ah, so my guess is that you've got a bleeding edge SDK which expects a kernel with Epiphany driver/module. However, the current kernel build doesn't have this AFAIK. Safest option may be to checkout an older commit of the SDK.
Someone else who knows more about this may also be able to comment further :)
Postby Pavel » Mon Jul 21, 2014 8:16 am
Pavel
Postby tincman » Mon Jul 21, 2014 11:53 am
tincman
Postby bert64 » Wed Aug 06, 2014 8:32 pm
Is there a kernel source tree available which supports the /dev/epiphany device?
bert64
Postby aolofsson » Wed Aug 06, 2014 9:01 pm
Currently everything is done through mmap and /dev/mem, but we are currently working on a new driver here (some exciting stuff....)
https://github.com/parallella/parallell ... any_driver
