Change Origin in HDF file
Postby msuthar25 » Tue Jul 29, 2014 9:09 am
I want to know if i can change the default origin of my epiphany III from (32,8) to (0,0) in the HDF file?
If not why?
Thank You
msuthar25
Re: Change Origin in HDF file
Postby 9600 » Tue Jul 29, 2014 10:15 am
Postby aolofsson » Tue Jul 29, 2014 1:50 pm
There are too many interdependencies at the moment, so I wouldn't recommend it. For example, you would need to change the FPGA code and regenerate the bitstream. Also, (0,0) wouldn't work since this is used as a local alias for all cores. (ie number without an area code).
