Correct way of mounting fs at startup
Postby AndyC » Thu Aug 07, 2014 12:00 pm
Hi Guys,
If I edit fstab to mount an extra filesystem on a partition on the memory card then the parallella doesn't boot, it fails to see the extra partition and hangs.
Whats the correct way of going about this?
Thanks for any help
Andy
AndyC
Re: Correct way of mounting fs at startup
Postby 9600 » Thu Aug 07, 2014 1:08 pm
See the nobootwait and nofail mount options.
Postby AndyC » Thu Aug 07, 2014 1:29 pm
Thanks Andrew, I will have a look....
AndyC
Postby aihaike » Tue Aug 12, 2014 2:18 am
@Andy,
Did you finally figured out?
I've created a new partion to full fill my SD card and realized that fstab was empty.
How can I mount it automatically?
Éric.
aihaike
Postby FHuettig » Tue Aug 12, 2014 4:45 am
Postby aihaike » Tue Aug 12, 2014 7:38 am
@FHuettig,
Thank you for your suggestion, it worked like a charm ...
Problem solved!
By the way, why is fstab empty?
Is it a ubuntu feature (never used it before) or because we are on a SD card?
aihaike
